I have a timberwolf 18/100 which does not throw the chip as far as it should. I have replaced blades and anvil
The fan looks ok but wondering if a new fan is worth buying? Do old fans loose metal/edge over a number of years?
The fans will definitely wear with age, like anything. Could be worth replacing, but it won’t be cheap.
It could also be that the B&S engine is just down on power after years of use.
If you need any help give us a call at Green Plant UK, the No.1 Timberwolf parts supplier. on 01483 235111, our technicians will answer any questions you have and I can help you with the parts. I will need to know the age of the machine as they have changed in more recent years .also the fans are only supplied in a set of 2 (a balanced pair)  . Gareth of Green Plant.
