Just noticed when changing blades on that there is a bit of wear near the blades - just wondering how bad it is and if it’s new flywheel time [emoji30]
40 minutes ago, Khriss said:
The bolt holes elongated ? You mean ?  K
No.... I'd say its the slight dish in the flywheel above where the bolts are.... the blades are mounted on other side, chip gets cleaved and comes through this hole to this side of flywheel before thrown out of chute....
It's what's to be expected of a machine at certain hours, bugger all to.worry about
That’s exactly it Swinny! Sounds good to me! Keep going
