TPO oak with fallen/hinged limb.
Sue J
I'm lucky enough to have a magnificent oak with a TPO at the end of my garden (but not in my garden)
It has just dropped a large  limb across x3 gardens.
My neighbours are understandably very worried about it.. not least coz kids play out the back.. and other low branches overhang other gardens.
Had a visit from council TPO guy today. Council/neighbours will get a survey done.
I climbed up and took photos (attached)
My first thought was that a previously cut back branch had been cut too long and had been unable to heal, and that rot might have travelled into the upper area of the junction of fallen limb to trunk.
(There is another long-cut stump immediately below the lower area of that junction, which is now supporting the hinge)
Having talked to a friend, he pointed out there are no fruiting bodies around that area. I've climbed again and infact the broken timber is quite solid.. not friable.
Fungal infection was discussed with the TPO man. Theres a soft dark area of bark at the base of the trunk at ground level directly below the hinged branch. Also a few small dark areas on that same side of the trunk.
So my questions are:
Was this a natural shedding of a lower branch? Or a sign of some deeper problem?
What can be done to ensure the trees future health and the safety of my neighbours?
(Girth of trunk is 3.95m)
Thanks
Hi
I think it has inspected fairly recently when one of the neighbours wanted it reduced. But that would have been in relation to the spread/crown and they maybe wouldn't have been looking for other health issues? They came and did a very light dead-wooding but no reduction.
Yeah I noticed the fold... but it appears healthy (no splitting) and is slightly offset from the fall point.. tho youre right it is close.
Thanks for response.
To me it looks like some of the fracture face is discoloured, as if there was a crack before (visible or otherwise).
End of the day you need an arb consultant report, for insurance and if anything will be done to it the council will need that. Don't get a tree surgeon to do it, get someone who does not have anything to gain from the work to recommend what to do, the only completely risk free option is removal so you want someone qualified to assess the risk and help mitigate if necessary but use removal as a last resort.
