Got the new veg beds in
there is a barely meter wide path
membrane and gravel
Then a hedge along one side
its full of ground elder
will it burrow across to the veg beds ?
if I crawl along dabbing on glyphosate with a brush just how carefull do I have to be of the stems of the hedge ?
its blackthorn and field maple mostly with some holly and other bits
they are probably quite safe but don’t want any disasters
any other solutions?
thanks
david
Glyphosate is absorbed through the foliage isn't it so the odd accidental dab on a stem should be ok I'd say.
Nature abhors bare ground; if you successfully kill off the ground elder she'll replace it with another coloniser - ivy perhaps or lesser celandine.
Be careful what you wish for!
