The post I hoped never to make...
Small fry in comparison to some of the other stolen kit on here but just in case you get offered some kit in the North East / Newcastle area...
I'm missing
Two (2) Echo CS-2511TES, one with a metal exhaust cover
One Husqvarna T540XP
One Husqvarna 550XP
A pair of Stein spikes
Assorted krabs and things
Keep your eyes peeled!
Rob.
  • Sad 4
10 hours ago, Paddy1000111 said:
Sorry to hear that. What happened?
Pop up the serial numbers if you have them?
Can't find the serial numbers at the moment. Sadly not written down but there might be photos somewhere.
Just to add, with respect to identifying the saws in case you see them:
One CS-2511TES had a metal exhaust cover, Oregon bar and is running a 3/8" chain. Probably running a bit rough since it was on my "to fettle" list.
The other CS-2511TES has a pretty new Echo bar and is running a 1/4” chain. It's also had a muffler mod.
The T540XP is stock apart from a Sugihara bar.
The 550XP is stock.
31 minutes ago, Paddy1000111 said:
That's a shame. I need to do my ones and I keep putting it off, need to do a proper kit list with s/no on them!
Do it!!
Need to do my gear as well,,,
But maybe you already have a head start: won't your climbing gear have serial numbers as part of your last LOLER check?
You ought to have the serial numbers of the saws on your receipts probably?
That might help get you underway, maybe?
Good luck with it
A
