Lots of variables, rope diameter, are you using a rope wrench?
Personally I use a courant phoenix 8mm X 75cm and run that on drenaline with a rope wrench tied in VT. Works a treat!
Edited by Paddy1000111
Hitches can be compact by using just a piece of cord with a stopper knot at the end.  The friction, or tension can be adjusted to your liking each time, very helpful with the VT.  A 4-2 VT in the picture, the stopper also helps with tending, can be easily done without a pulley.  I first tie an overhand for the stopper, test it, then add another behind it.  The tether is 8” and still has room to not jam the hitch.
Great information thanks buddy. Running moving ropes atm - *till I learn the ropes*
