Stainless steel shell -could- be there to make it look nicer and not affect the stoves operation.
When I was looking last night I had a feeling that the top hole should have a cover on it and for some reason thought it would be removable with a handle or something but no cover shown in the pictures. If you take the pipe out the back as a flu connection (controllable which does happen to dampen the fire), then the top hole doesn't make sense to be left open as part of a passageway for the smoke - it wold flood the room with smoke. There might be alternative flu connections of course for a more versatile installation. If so is the back connection removable, if not then it only has 1 flue connection. (and then going by these guesses, rear flu, with a hole on the top... what is that hole for?)
The next piece to work out then is maybe fuelling the stove. Can you get a log in past the grid at the front? If you couldn't get a log in then it isn't a log burner and is for smaller stuff like coal, chips or pellets. it isn't a liquid stove because it has an ash pan and no feed pipe connection from what I see.
Hi Steven,
there is a lid at the top (quite a heavy one)
there isn’t enough space to sit / burn logs at the front where the grill is. My thoughts were that it was top-loading and logs would be fed in through the opening at the top.
the rear connection / exit with the butterfly valve isn’t removable
1 hour ago, Paul in the woods said:
I wonder if it is some form of rocket mass stove?
Maybe, just been looking at saw dust burners and stoves. similar apart from the bit at the bottom
Now the flue on the back is shown, it’s more evident. It looks a bit like a pellet / chip stove I saw in a holiday property in either France or Germany.
Definitely not connected properly though, so not recommended to light it as is!
