random question.
Today we felled a leaning woodland Ash, approximately 28" in diameter on the leeward side of a copse.
Tall tree 75ftish.
As we all know, soon as some timber is felled the stress release fractures the timber.
upon the floor after 5 minutes we heard the normal sounds of Ash letting go.
I am hoping to return to the trunk in the next week or so as there is a lovely wide Olive colour band.
Currently the log is approximately 25ft and ill need to cut to remove it in sections from the property.
Normally i throw the logs on to my new milling pile, however i am concerned that once the stick is cut again more stress will be released.
Am I best to be cutting up the pith straight away, or leave for a while as normal?
It’s firewood probably.
With that much t&c it’ll still split sooner or later.
You could leave it in one piece off the ground for 3-5 years til it’s stabilised, but I suspect it’ll pop.
If it’s really nice colour, just mill it and see what happens.
There always resin table makers.
[emoji106][emoji106][emoji106]
It will probably  have developed reaction wood in response to the lean and will be far more likely to warp / split ..the tree is talking to you 😉   an old timber merchant I knew always used to say if the middle is not in the middle then it is no good !!
Not only have I been obviously paid handsomely for the removal, but with his now new large stash of ash logs he doesn't require anymore logs 😅so the trunk is free to a good home 😜
Will see how we go 💪
The main stem, to that fork is about 22ft and dead straight.
