18 hours ago, andy cobb said:
Sounds like a good plan, are you going to use bucket blade sharpened up?
I don't think I've ever used the 4 way so if your creation is successful I might just steal your idea!
Yes a length of bucket edge & attack it with the bench grinder. One sided points for the ring & two sided for the additions.
Bloke on ebay selling add bits of edge.
17 hours ago, andy cobb said:
Have a look on wearpartsuk.co.uk and look at bargain blades section, has a list of short offcuts around 18", they specialise in hardox so might have something you can use
Already bought a 1m off cut from ebay but thanks for the link.
17 hours ago, CallumA said:
Be very careful not to compress the timber going through the knife. I made a 28 way for a 60 ton spiltter and it was great on straight grained stuff but when it jammed it took ages to clear it. Ended up scrapping it and making an 18 way. So much better but still a bugger when it jams. Only use it for sticks over 20" now as its not height adjustable so loads of small stuff with smaller clogs.
Thats a bit of a monster.
Yes I will be setting them at a slight angle & using the single sided knife method rather than a two sided wedge.
Keep us updated, I was thinking about it today and I think it's a grand idea, the only issue I can see is if a knotty piece is split and it puts enough pressure on 1 side to twist the splitter knife, without significantly strengthening the trough around the knife to enable support bars to be fitted I'm guessing theres no way round that though
Just the same as now on the 4 way & 6 way.
You often get a log that is one sided & makes the knife try to twist.
The knife holder is quite substantial.
  • 3 weeks later...
31 minutes ago, andy cobb said:
Justme, did you manage to build your new splitting wedge? Eager to see some pics of you did.
Not started yet, too busy working on the trailer/processor/crane/engine combo.
I got a bit further with mine, transit engine now running nicely, and got a right angle gearbox from a round baler that has 6 spline shafts on each end and alters direction of rotation so have all forward gears to choose from on transit gearbox, just have to join everything together now.
I have mounted the engine, need to service it & cambelt then fit rad & intercooler.
Currently trying to source 90 deg box. New are about £280+vat. Or back to using the rear dif off doner vehicle.
Third beam welds
Third beam added to the kelfri log deck that has also been lifted at one end.
Work platform down
Work platform up as a trailer side
Crane reach to the rear.
Should give me a good 6 to 7 meters of stack I can load before needing to move trailer.
Engine cradle
engine1.thumb.jpg.c89375308d233e70632527366b43a4f2.jpgengine2.thumb.jpg.c8fef50e24f56e10adf9a2b61cc5bf84.jpg
Looking good, before I found the baler gearbox I was going to buy 1 from tractor factory, it was listed under topper gearboxes, but if you do see an old round baler try and buy the front gearbox, they're really heavy duty.
Does the iveco need much in the way of electrics to run?
