19-28 sheers bars
Clicky
Hi
Come to flip the shear bars on my 19-28 tow along and have noticed the vertical has cracked. Anyone know where I can pick one up from this week if possible? I've seen orangeplant have quadtrak ones in, that look very similar but not sure if there the same?
Thanks Matt
3 hours ago, Clicky said:
Hi
Thanks Matt
@Jase hutch may know. Parts diagrams for the quadtrak may be in the manual which is probably a download on the Greenmech site so you could compare part numbers. If the vertical one is cracked I suspect you'll live to regret hoping it will last. From the numbers it may be common with the older 220.
The 1928 has three shear bars
 EC1928-2-31
 Top shear bar
  EC1928-2-29
 Lower shear bar
  CM220-2-31
 Vertical shear bar
 EC1928-2-31
 Top shear bar
  EC1928-2-29
 Lower shear bar
  CM220-2-31
 Vertical shear bar
Yes I think it's the same as the horizontal shearbar in a 220..
