GREENMECH 150 Hydraulic Coil alternatives
Flo
Hi Everyone I am looking for help My GreenMech 150 has developed a feeding issue stops feeding after around 5 or 10 minutes of use then starts again after a little while I have found the Hydraulic valve forward feed roller coil to be the culprit partnumber #PQC 160-6-9018 unfortunately GreenMech has stopped dispatching parts for the hols and won't be starting until the 5th of Jan again does anyone know of a alternative that can be used?
Many thanks Flo
8 minutes ago, Jase hutch said:
Or swap the top and bottom coils until you can get a replacement  ??
The faulty coil should be ok on reverse as it won't be used as much so shouldn't overheat. And you'll have the good coil operating the infeed.
Jase.
Good shout will try that tomorrow 👍🏼
  • 3 weeks later...
