Cleaning chipper blades
karl
We have discontinued our shredders which is why they are not listed on our website.
However the product pages are still live and they feature videos - here's a link to the road tow version:
TIMBERWOLF-UK.COM
The Timberwolf TW S426TDHB Wood Shredder reduces the volume of green waste efficiently with its large infeed and powerful heavy duty steel hammers
If you need information on the tracked or PTO versions just us know. The manuals are still listed on the website if you need technical information.
On 11/11/2020 at 12:40, gdh said:
I just use a flap disc on a cordless grinder which is pretty quick.
Trouble with this is twofold- one, you will readily abrade the metal, and this on the mating face is not ideal. Two, flap discs clog very easily, and this would be as bad as millscale for clogging.
Give one of these a go, I reckon it would be much better suited. We use them a lot for cleaning and polishing up cement trowels, which is a similar application.
WWW.TOOLSTATION.COM
For effective removal of rust, paint, thermal blueing and other contaminants with minimal risk of scratching the workpiece...
3 hours ago, Scottish Cleaning Service said:
WWW.NORFOLKSAWSERVICES.CO.UK
Big range of Tormek bench top grinders and wet stone grinders for tool sharpening from Norfolk Saw Services
I bought one of these wet stones decades ago to sharpen my joinery chisels. Great piece of kit and still going strong and never burnt an edge. I will probably try this to restore an edge on my chipper blade. If the blade is too hard then I will let the saw centre sharpen it.
Change the wheel out for a CBN one and you will never look back. Only thing with the Tormek is that it's so slow- will probably take an age to do a blade.
There are some Chinese blade grinders on eBay that come with CBN wheels fitted- might be worth a look. You can run CBN much faster than wetstone and it still cuts cooler and sharper.
