2 hours ago, peatff said:
 It has a decent bar on it but if I change it I would like to try a 10" replacement. What is the bar pattern on them anybody ?
I have a A041 on mine.
It might work the Husky 338 bars in A095. But havent tried that yet.
Up the page a bit I said I fitted a Stihl narrow kerf bar and chain - had the clutch cover off at the weekend so cleaned it up took a piccy, see attached.
TBH I'd forgotten the detail - you can see it needed new holes in bar for the tensioner and oil feed..... What you can't see is the hole to connect through to the bar rails, bit tricky that one only 1.1mm dia.
Chain oils OK but surrounding area is also pretty oily so maybe not sealing too well.... I'll turn oiler down to min.
