Primer bulb drawing air
Phil H
1 hour ago, Phil H said:
A quick look-see yesterday, all spotless inside, all looks ok apart from there was no washer under the screw that holds the top of the carb on - presumably this is required & a potential source of my issues?
Hopefully give it a whirl today.
No washer on any of mine so it's not going to be your cure. The casket under the casing seals it.
Regardless of the bubbles does the bulb 1/4 fill? and does the machine run at all?
When cold, yes the primer bulb is fairly full & the saw runs fine.
When hot (say after 5 or 10 mins cutting) the saw will bog/cut out, primer bulb struggles to pull fuel & the saw won't run but is ok again when cold.
