.50 gauge bars/chain v 0.58
Stere
12 minutes ago, Stere said:
What is the biggest saw that would still "suit" 0.50 over the 0.58?
60cc?
What  are the disadvantages  sawdust/chip clearance from cut  bar durability?
I run 050 on my 550 and 562. The chain speed in the wood and smoothness in the cut, especially when bore cutting is better than 058 in my opinion. I use Sugihara light type bars from Rob D as they are stiff and durable even in the narrower kerf. I found the narrow kerf Oregon speedcut bars pretty durable for the money but don’t rate the speed cut chain that marries up with the bar, I use Husqvarna SP33 instead.
1 hour ago, Stere said:
Thanks Stihl has there own versions now also.
WWW.FORESTRY.COM
In 2020, Stihl will release a new saw chain with a .325” pitch and a 1.3 mm gauge. The name is Stihl RS or RM, with the...
For the 562 did you have  you change the  sprocket?
Yeah, I found it a bit sluggish/clunky on 3/8 compared to the 560 so switched it all to .325.
I use Stihl RM in 058 quite a bit on my 346’s for cutting chestnut coppice, it is a very durable all purpose chain, holds its edge very well.
I bet that RS Pro on 050 will perform fantastic in a stand of softwood, I’ll be giving that a go.
Edited by The avantgardener
Using a husky chain on my 346 atmo not the newest hooting n hollering one (orange n white'sh box)cuts pretty good thats 325 058 looking at the .50 to try out with new bar Sugi pro lam 15" and the Oregon 95TXL
