57kgs.
Could probably get away with a lighter log type grab but I prefer brash grab.
We fitted extra ballast which makes a difference, operator is standing around 8 inches further back so his weight is more effective, also a more comfortable standing position especially in high speed tracking.
41 minutes ago, s o c said:
40mm solid and 20mm plate.
on and off in a few minutes
Great shout, Might offer something similar as an option -  wondering if you'd get away with coach bolts down through and they'd get in the way a bit less?
Yes. I just used threaded bar, might weld bits of flat on top.
you could also tap the holes in machine and countersink Allen bolts, then you’d have nothing protruding up or down
Yeah that would be the one - 20mm plate is plenty to loose an m16 csq bolt
Manufacturer has also bigger backplate there if asked. I just had some word of that because I was thinkin that tracks need some protection on back. We have seen now that in some position your shoe touch the tracks and thats not very pleasant.
