Hi
As above, does anyone have the part numbers of what I need to order please to convert 880 to run 3/8 bar and chain etc
Think it's been on here before but can't find it
Thanks
Hi try this guy
WWW.CHAINSAWBARS.CO.UK
Chainsawbars - Largest selection of chainsaw guide bars and chainsaw chain for Stihl, Husqvarna, Echo and Dolmar...
He does all the bars also as there is a mount size to take into consideration also spacing out as 7 tooth 404 is around same size as 8 tooth 3/8 but you have to watch how far bar comes back onto clutch drum. But he will know the figures
10 hours ago, AngrySquirrel said:
Hi try this guy
Cheers I'll see what Rob says ?
12 hours ago, Rough Hewn said:
It's easy.
Put a 3/8 rim sprocket on.
Done.
(With the duromatic bar).
Just need to work out how many drive links...
ok thanks soul
am i right in saying that i'll be able to run 3/8 chains but not the same bars as i do on 660 etc?
or are those adaptor available that'll allow me to do it?
thanks alot
Yep 660 bar wont fit on an 880, but an 880 bar will fit on a 660 with an adaptor. Unless you machine the 660 bar mounting slot out, 12mm to 14mm IIRC
Edited by htb
ok thanks mate. i was hoping to save some ££ and use the same bars and chains somehow!
Not happening/don't do it.
3002 mount (880) bars are considerably larger than 3/8.
Stick with .404 on the 880.
[emoji106]
cheers mate. i'll be sticking with the 404
just hate sharpening those things :lol:
