Full wrap is really a big trees thing in other places, but it can be handy  imo. (pun-intended ?)
it’s also bulky, and you can’t stump off to close to the ground.
as for the exhausts chainsaw are another breed. You only have to read the many different ways peeps mod them for power/noise.
heres my rebuilt 10mm, inc main bearings & powdercoat
https://youtu.be/dxXYey71LhI
Edited by Wonky
cuts ok 20" bar? mines got a GB pro 20" .was looking at the blue parts from farmtec/holz
Mine were blue ?
now there black ?
i cut some more beech  disco's  today.. 20” bar  and a log to use the whole bar.
Edited by Wonky
On 09/04/2020 at 09:00, Wonky said:
heres The beech, between 1st cut and second cut I leaned it out a 16th
Whats the thing with cutting the biscuits/cookies? keep seeing it everywhere mind want some for carving/making things.
Need to replace my rim sprockets i think?
On 11/04/2020 at 10:34, Wonky said:
it's just a name for cutting thin bits of wood when your testing a saw & chain performance and your limited with the wood you got.....
Got DP muffler on way found more than one though! Filter,plate,cover and top cover plus the metal bracket probably need screws/nuts/bolts for it as ones onit now will probably be wrong?.ordered two rim sprockets for it and 372 plus bearings and will need to sort 346 ones out also once pull clutch(Three legged puller should do it?) Keep looking at wrap round handle! Slap put hands back in pocket away from mouse!
Don't know about Covid but these bits are very infectious!?  Got filter kit for 372 coming? one on youtube Bucking billy ray has a dual port on 372 they have a tube coming out of either front side it sounds nice also
