Hi, i’ve got an old BC620i with a Hatz 2G40 engine. It was given to me in a rather sorry state after about 5 years of poor storage outside. Anyway, it needs a new belt and i’m having trouble locating one. It’s my first foray into the world of chipper belts and maintenance so i’m learning as i go.
the belt is a dual band v belt and theres on ebay but its in the usa and comes to a whopping $144
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F333353030046
the current belt is marked 8DSS
and i believe is a b73/02 and i think the original belt is coded V-86522-001.
So i’m sure someone here can point me in the right direction to get a new one.
Most bearing stockists also do belts etc. With those numbers they should be able to source you one,
Hi there, we also have a BC620i. We swapped the engine for a Deutz when the Hatz give up. We run two separate belts. Take your belt to Compass Bearings & Engineering Supplies in Rainford and they should help you out. If not try Engineering Services In Widnes but they are a bit more expensive
30 minutes ago, T&Gliverpool said:
Got two separate belts for it midweek from engineering services in widnes, it runs much better now and cost about £24. Great ???
Worth noting that two separate belts can be +/-3% on width, +/-3.5% on height, +/-3° on angle unless ordered specifically as a matched pair. You may find one is doing a bit more work than the other until it sits down in the groove and is re tensioned . Bonded pairs or multiples are exactly the same length.
Bob
