I have a ms362 (2011). Had it from new. Not a lot of use. It's always been a bit unreliable. Latest problem is getting it to idle correctly. It goes from the chain spinning, to stalling, with only the slightest adjustment of the idle screw. Done a factory reset. Running fine at high end. Any suggestions? Thanks
5 hours ago, spudulike said:
Factory reset??? It can't be Mtronic from 2011:confused1:
I take it that it has a normal adjustable carb?
Yes. What I meant is I've reset it using the instruction manual. Think gk  has got it
Edited by Con
Forgot the main question
