Polyethylene glue
Roby
Thanks guys,
I was looking for hours how to...
It seems that there is no glue really for this kind of plastic.
I'll empty the can and try to use a hot screwdriver to melt the crack a bit than melt some of the same High density P. E. plastic.
It is a horizontal crack on the oil part under the thread.
Will bloody work! :) Criss cross fingers!
Cheers
Hi mended a plastic fuel tank of a quad a few years back that had been chewed by mice, took tank off and filled with water for 24hrs then left it with fuel tap open and cold water tap trickling in to it for a few days, left to dry out then fixed the area with leak with a red hot glowing knife and bits of zipp ties, worked fine
Rough!!! Expect nothing else from you of course! Cowboy ?
