Cobra Bracing
Martyn Honey
27 minutes ago, Martyn Honey said:
I came across this cobra bracing, on a large Ficus, while on a Christmas break in Cartagena, Spain.
Not seen this amount in one tree. A lot of it was very slack and not doing much of a job.
The tree was in a large Square, so probably looked after by the local authority.
Martyn
I don't think it is meant to be bollock tight . There has to be some allowance for  limb movement .
As Steve said - its to prevent issues with shock loading in the event of failure.
 The movement comes from the use of the sling that allows the branch to rotate unlike with the old steel pins that went though the branch.
