Hi all
Can anyone point me in the right direction to find a grain bucket that attaches to pallet forks on a telehandler?
I have an old Liner Giraffe and the headstock is fixed, so no quick release.
Cheers.... Al
The old bonser forklift buckets hooked on the same as the times (the had tip built into a back plate but you probably won’t need that bit) , you slid the tines to the centre to take them  off, then the the bucket hooked on and had 2 blocks that bolted on in place of the bottom lug on the tines.
I will try to find a picture, my dad had a rough terrain one based on a DB tractor back in the 80s/90s
This company do clip on and drive in; Drive in at bottom of page.
WWW.MURRAYMACHINERY.COM
The Murray Forklift Hydraulic Tipping Bucket is designed for standard mast type forklifts where there is no hydraulic tipping mechanism available. The hydraulic tipping bucket consists...
Thanks guys.
I'm picking up an old grain bucket off ebay on Saturday, and will get it modified to fit the tele handler. The forks on the telehandler have a tip function, so should work.
Cheers.
