25 minutes ago, markrufrider said:
anyone got pics of muffler modded 362/360 they want to show and how much of a difference is it made as im going to get a 362tes soon
Basically i removed the silver coloured deflector from the exhaust and used a dremel to cut a 'U' shaped access hole in order to remove the 'CAT',  i bent the steel upwards in order to access the innards, then all i had to do was to press / bend  the steel back into shape and screw the silver deflector over the top.  Spud tuned it up for me and it improved the overall performance of the saw.  I may have some pics. somewhere.  I would love a ported and muff modded 360T /362T.
Edited by wicklamulla
ok cool was it an arse to actually get the cat out or relatively easy ?? yeah i haven't seen anyone post pics vids of one modded on hear or any where a timing advance make a big difference im keen to see if i can get one to be a 201t ripper
once i cud see the CAT i mangled it with a screwdriver and a pliers in order to make it smaller and get it out of the access hole i had made.
  • 1 month later...
picked up my brand new 362 top handle today already muffler modded it spark arrestor pulled out love it great saw feels good waiting to get carb screwdriver give it a tune as she runs in and let it rip
Mark did you drill to muffler to bypass the CAT?
A timing advance on the Echo CDi ignition systems seems to have no effect on performance. The Echo already greatly advances the timing when it's in the cut. It does't even really help the pick up/revving.
yes i did pull the exhaust of and drilled it out from the back just need to give it e retune and see how she rips waiting on carb adjuster screwdriver set to arrive in post lost my only one i had
