Hello, I have recently brought an Atco Royale B24. I have no idea what age or model it is. It has a Briggs and Stratton 5hp engine and is electric start. The clutch cable clamp has broken and I need a replacement but am struggling to get the right one for my mower. I have attached a couple of photos of the clamp and of the machine. As you can see the teeth are broken that hold the clutch cable.
Age: To give you a rough idea, unless it's had a replacement engine.  You should see a set of numbers Model, Type, Code,  stamped into the engine cowling, either down the front face, or across the top.  The first two digits of the code (the last long number) is the date of the engine.
As for your clutch cable problem, I'm not seeing any pictures of the part you mentioned for some reason.
48 minutes ago, CM123 said:
Thanks lurkalot, sorry forgot to post the pictures of the part. Here you go.
Could that not be brazed / welded ?  or is it plastic ?
Edited by Stubby
