I've got a couple of the Bli200 batteries, generally use the economy power setting which is fine for nettles & bracken etc. & probably lasts +/- 1.5hr. Thick patches of tall grass make it work harder which might bring it down to 40-50mins with full power.  Even so gives enough time to charge the spare battery providing you have a power source. Nothing in the manual about power of motor either.
My (very) old 2t Stihl was 31cc & I'd say it's a match for power, probably not as robust so doubt it would take the abuse the old machine suffered or even still be running after 30+years.  These days I appreciate that it's a lot less tiring to use & vibration is a fraction of an ICE machine, with the motor at the head there's no drive shaft so much lighter & no torsion when you squeeze the trigger.
11 minutes ago, Stere said:
Those batteries & charger are  expensive
Your not wrong,  I now have battery chainsaw & lawn mower as well so hoping the investment will pay off.  So far so good, have cut 2 winters worth of logs, mown the lawns & kept paddocks clear of weeds with no petrol.
  • 3 months later...
Just read there's a new husqy battery brushcutter coming out "in 2020"
Here's a video from Sweden, if you go into the settings you can select English subtitles
Looks a decent enough machine, it has the motor at the battery end, supposedly making it more rugged, and apparently matches with a 35cc petrol machine.
Would be interesting to know a date when it will be available in this country, and a price!
I do find the Husqvarna model numbers a bit confusing, doesn't help they have changed some about!
It looks like the new battery stimmers/brushcutters in this country will be 535iRX and 535iRXT
WWW.PITCHCARE.COM
Husqvarna have announced the launch of two new powerful battery-powered brushcutters which will raise the bar for...
"The Husqvarna 535iRX/535iRXT brushcutters are available from February 2020 at Husqvarna authorised dealers and are priced: 535iRX (£519.00) and 535iRXT (£599.00)"
I hope there'll be a good discount! :tomato:
  • 1 month later...
Well, the Husqvarna 535iRX seems a good bit of kit
Have only used it briefly, but I imagine it will take away a fair bit of the work normally done with petrol machines. Very nice to use, quiet and low vibe.
It comes as standard with a basic (but comfortable!) harness, bump feed head, tri grass blade, and a saw tooth style clearing saw blade.
:bandit: :001_cool:
