Sign in to follow this
Mark01987
Ms200t not turning off
Hi,
Have just been donated a 200t that I wanted to see if I could get working again. The main problem with it, as far as I can tell, is that it won’t switch off. I’ve checked the earth wire in the handle (seemed fine) and then checked the ignition coil wire. The piece of metal coming from the ignition coil that the wire slots into seems to have snapped off.
First question; is this the problem? Pretty sure it is but there’s certainly people who know more on here!
Second question; if so how hard are they to replace? The wire to the spark plug looks like a right bastard to get through as it runs right through the body of the saw! Not sure if it’s something I want to do.
Thirdly; is it a pricey fix? There are a few other things that need doing to it but seems to be running pretty well on the whole so would be nice to have a saw for cheap!
Cheers,
Mark
Share this post
Link to post
Just resolder the broken connector or a fabricated one on to the coil. Relatively simple job and yes, it would cause the non stopping issue issue.
If you want to fit another coil, the HT cable can unscrew from the coil and yes, removing the HT cable isn't a simple job.
Edited by spudulike
Share this post
Link to post
1 hour ago, spudulike said:
and yes, it would cause the non starting issue.
= and yes, it would cause the non stopping issue.
Share this post
Link to post
Don't know what you are talking about:confused1:;)
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
