They're generally shorter, more compact machines, requiring less weight to tipp them forward, where as avant style loaders are longer, normally with the engine and weight over the rear wheels.
Its the Tipping weight which is the important number to look at, the "lifting capacity" is normally what the lifting arm will lift, at the attachment mounting plate, with the machine chained to the ground. Tipping weight is how much the machine will lift before tipping forward (not chained to the ground!)
