395xp chain brake
Fredward
The chain brake 'off' action on the 395xp (well, at least on my saw) is terrible. I believe that this is pretty normal, and I always attributed it to the old design with the one sided lever mount. However; recently I used a 3120xp, which has the same style mount, and the brake is much MUCH better.
Video here
I wondered for a minute if the two side covers were interchangeable, but after a quick look side by side they are obviously not. Then I went away and wondered if it was a shorter/weaker spring. I ordered the 3120xp spring just to compare them. The 3120xp chainbrake spring was longer, and larger diameter, so not a direct swap and unlikely that it is 'weaker'.
Has anyone got any ideas on rectifying this? I am aware that modifying a safety feature really isn't ideal, but the brake is currently so difficult to operate that you tend to just ignore it.
Edited by Fredward
Looks to me that the actuation is similar and it is only the pulling back of the handle/guard that is more difficult.
Most 395s I have had in are like this. About all you can do is make sure all the parts are clean and are not worn then grease them on rebuilding.
