TW125 feed roller stopping sometimes after no stress comes on
mattyboy
Just changed the stop bar switch as feeding in wasnt happening and its sorted 90%. However about 1 in 5 times the no stress comes on the forward rollers freeze and i have to press in the go switch again to get rollers to feed in again. Any ideas why this may be, maybe a loose connection somewhere?
Just a thought, Have you tested the battery?
I had a load of problems with my feed rollers/no stress and I charged my battery up and it solved it.
Tw125 does not have an alternator, just relies on a coil on the flywheel to send a bit of juice back to the battery, so unless you are using for long periods of time, it will slowly wear the battery down, which will then affect the electrical system.
Give it a go...pop it on charge tonight [emoji106]
