Poulan Wildthing 2375 compression
goosemasterkl
One little question, have you compared another small engine compression with the same gauge as some gauges are ONLY suitable for car engines and will read low on anything else.
You should have around 140+psi and 150-170psi is where it should be on a healthy engine and a suitable gauge.
