Depends what you want to cut with it. It'll pull a 28 fine but if you've not got that size timber to cut then I'd probably stick it on a 20, will fly through timber.
From what I have seen, it can oil up to a 33" bar, so you're good there. It all depends on what sort of cutting you do. If you man handle it a lot, bore cut often, and back bar it at the stump, you'll need to tailor it to those needs.
