New “Black”Cone Splitter
Bustergasket
Well i have been mulling over the perceived pros and cons of using a cone splitter for a while, this is the S2X800 model, picked it up yesterday from Fuelwood and managed to split some of the larger diameter lengths last night, it was a doddle to get the hang of even in the dark with only the digger lights on, iam running it on a 4ton machine, plenty of power, i had the 245mm cone, probably should have gone for the 300mm option, but like all these bits of kit until you have used them you just don’t know, i cannot see any downside to using the biggest cone possible (maybe wrong) i would estimate i split 10 ton in two hours, now originally i was going to reduce the larger dia 500mm stuff so it would go through a processor, however i was surprised to see the timber was 20-25%, so decided to bust it smaller and used for boiler fuel (running a bit low) i plan on grading the straight stuff to the processor and the gnarley stuff for boiler, i think iam going to get on well with it for producing boiler fuel and getting some of the nicer stuff through the processor, it splits huge volumes very quickly and the slivers are welcome boiler fuel, i will put done more viewpoints up when i have had time to use it s bit more, here is some picsIMG_4164.jpgIMG_4166.jpgIMG_4169.jpg
Well i have been mulling over the perceived pros and cons of using a cone splitter for a while, this is the S2X800 model, picked it up yesterday from Fuelwood and managed to split some of the larger diameter lengths last night, it was a doddle to get the hang of even in the dark with only the digger lights on, iam running it on a 4ton machine, plenty of power, i had the 245mm cone, probably should have gone for the 300mm option, but like all these bits of kit until you have used them you just don’t know, i cannot see any downside to using the biggest cone possible (maybe wrong) i would estimate i split 10 ton in two hours, now originally i was going to reduce the larger dia 500mm stuff so it would go through a processor, however i was surprised to see the timber was 20-25%, so decided to bust it smaller and used for boiler fuel (running a bit low) i plan on grading the straight stuff to the processor and the gnarley stuff for boiler, i think iam going to get on well with it for producing boiler fuel and getting some of the nicer stuff through the processor, it splits huge volumes very quickly and the slivers are welcome boiler fuel, i will put done more viewpoints up when i have had time to use it s bit more, here is some picsIMG_4164.thumb.jpg.302ff00e20653b51e6c13180460eefab.jpgIMG_4166.thumb.jpg.43fc24768f2843d1946612e847aba19b.jpgIMG_4169.thumb.jpg.2fb406076b75c828901b0109551a192c.jpg
What do they compare like price wise to a lasco ?
Have to be honest Matty, i did not price a lasco, i think both bits of kit will do the job, and it’s surprising how fast they bust stuff up, as is seen by Stephen’s reply earlier in the thread, i think that’s on a bigger machine, but from what i see i think the small versions are just as impressive, prob just don’t have the reach and are very slightly slower, you just let the cone bite and it takes the timber, no pressure needed other than to stop it rotating the timber, i can see corrosion to the cone could be an issue as it will increase the friction, working on a silicone boot packed with grease, does anyone else do anything when not in use ?
