Looking for some advice from more machine-minded people than me.
2 days ago while cutting up a Palm, my (not very old) 660 stopped in the same manner as if it had run out of fuel. There was plenty in the tank, allowed it to 'rest' for a bit and it started again without a problem, then stopped and won't go again.
I've checked for a spark and there is one, the cylinder smells of fuel, but it's not going bang!
Before I attempt a carb strip-down, I was wondering if anyone has any other ideas?
Oh yeah, the tank filter is clean.
Edited by Lurcherman
More info
Thanks to you both for the advice.
As it was anice sunny afternoon, I took the carb apart, blew everything through with the air-line, bolted it back together and away she went!
Thanks again.
might want to check the tank breather its a plastic pipe with a threaded screw inon top of the tank, in it take out the threaded screw and hacksaw a slot 90 degres to the threads then put back in u should be able to blow trough it.this being blocked give the same symtoms as running out of fuel,hope this helps
