This weeks saw conundrum !!!!
My 020t was occasionally racing during a days use but largely fine. Great at starting and oodles of power.
I though however I’d change the carb to a Chinese model but have found that although it starts fine and revs fine, it won’t run on idle even with the idle screw wound all the way in.
I have swapped back to the old carb but now it’s the same , won’t idle.
I’m stuck as to what could have happened .
Any ideas gentle folk ?
I’m baffled [emoji53]
Wondering if it is an air leak issue, how old is saw ? Been problematic previously ? Done all yr usual service checks air-plug- filters etc ?
Yes swapped plug, does it without filter and fuel/breather hose is less than 12 months old
Would look for something happnin recent like a drop from height or dodgey fuel mix. I would have changed carb diafrags an spark plug n go from there. K
Could the rubber boot thingy between carb and cylinder become damaged / dislodged?
(Or is that what spud said but only in fancier language?).
