Hello,
 I have read a few posts on this side of the forum about air dried firewood.
Certainly most of the hardwood punted out in Brittany by small scale sellers is high in moisture and requires further seasoning.
In reality, air dried is likely to achieve what level of humidity in the U.K? (Wales similar climate to West Brittany)
Is 15% achievable without a kiln?
 Stuart
Simple equation. Find your closest weather station on here https://www.wunderground.com/wundermap Sometimes worth checking a couple of station as you get the odd one giving strange readings
Set it to look at the last month or two's humidity and temperature. Then put the numbers into this https://www.woodworkerssource.com/shop/mois.html and you have the best you can do. Looking at few sites in that area 18-19% is about as good as you can get in the winter
Can't get 15% here unless sold in a nice summer
Edited by Woodworks
1 hour ago, Luckyeleven said:
Size of logs here is far too large IMO
From the man who has fitted a 60cm log capacity wood boiler...
 You are right though.
Short logs are going to dry faster in this climate.
 Stuart
 Stuart
Girth is the important factor dear boy!
