1 hour ago, surveyor said:
The Husquvarna file holder allows the round file to be rotated as you file.  Also the raker file can be removed or turned over easily if so desired, as the holder slides open so that the round file can be swapped sides for either side of the chain teeth.
Which one are you referring to? Can you link to it?
