Can anyone advise me on how to adjust the position of the flywheel on my Jensen A540T? The knives are sitting a little close to the Anvil.
Any help appreciated.
Many thanks
The ideal gap is around 1mm so there isn’t such a thing as too close, unless they’re touching.
The pillow block bearings are moveable in little slots, back and forth if it’s like the Forst.
I am told they’re a similar design, I may be wrong though.
I was told .5mm on the far side and 1.5mm on the side closest to the shaft.
The disc will warp when it hits a big bit,too close and you might clatter the anvil.
You won't get the blade to anvil gap even anyhow.
