I always feed a length of ratchet strap webbing under the rollers ( top or bottom rollers) to aid in lifting out/in the rollers. Makes easier work of it.
Bob
31 minutes ago, slasherscot said:
mines 3yrs old n january......lower roller a bit harder to get out but still better than old 150 bottom roller
Didnt have to remove mine.... Just remove the end cap on the roller box.... then green bush is revealed then you can see the shear bolts
  • Sad 1
