Power Inverters and Electric Saws
jamiep
Hi All,
Anyone used an electric saw with an 12volt DC Power inverter?
I’ve got a handy little 750 watt saw and plenty of decent batteries but not sure what size inverter I’d need, ie would a 1500 watt continuous output be ok or too much/not enough etc?
I’ve got petrol kit but the electric option works well for weight and noise where I am.
Any thoughts or experience gratefully appreciated, cheers :)
750/12 is about 63 amps, that is going to drain most batteries in quick time. With a lot of inverters they usually cut out after they sense a voltage drop in the battery of about 1.5V. Think it would cause that cut out fairly quickly ( one minute at a total guess) in all but good and big batteries.
Also cables are going to have to be up at about 16 or 25mm  to handle that sort of current.
Edited by roys
Additional info
