Installation advice, Sena 10R (low profile one), Protos helmet
There are some photos on another thread from a while back if you have a search.
I have the battery stored on the inside back of the helmet with the control on the outside on the back.
Speakers in the ear defenders with a notch taken out with a drill or file to allow for the wire.
Tidy the wires up inside the helmet with small zip ties or tape
As above but make sure that the holes you make in the ear muffs are deep enough otherwise you’ll cut the wire when you put the ear cushions back in place.
Like I didn’t, honest.
I protected the wires with a bit of electrical tape just at spot wear hole is cut to make sure the wire wouldn't wear through the sharp edge on plastic and great a good seal
