I use a Samsung 10" tablet and online application we constructed ourselves, there is a lot of good online software out there if you have the time to sort out a setup. Much lower cost than Eezytree or similar. Plus no licensing. Ours geo locates and sits on Web so client can look at it within moments of filing data. K
( Google map based )
Edited by Khriss
Remembered summat
  • 3 weeks later...
Axciscape (via Chris Skellern)  import export into cad,import pdf's/ google maps etc  user defined fields. https://www.axciscape.com/
We have used this for years
Pear technology have  range which a lot of people use with and without mapping .https://www.peartechnology.co.uk/
Then if into cad Keytree is one of the cheaper ways to get an up to date CAD engine
Rugged tablets various from the more common toughpads and now  tree diagnostics   www.treediagnostics.co.uk sell sumo tablet products for forestry/tree surveyors.
The rugged tablets lets you work easier in the rain than non rugged and you can drop them without worrying!!
It depends what out puts and what type of surveys there is also a few others which I just cant remember the names !
  On 06/11/2018 at 09:26, David oakman said:
Khriss your set up sounds good to me.
I have got to survey trees on 6000 acre estate roads houses etc but need to cut out paperwork
Expand
I can email over the details and an example form we use, David, the system is Web based so a Chrome browser is best. Then you just construct the forms to suit yr requirements. K
Read more
