I did read up on this. The EGR cooler could be to blame. I assume if you blanked the EGR off (purely for offroad use) it would mean no gases passing through.
I blanked my EGR off (purely for all use ) years ago . I think its a pants idea .
Obviously a fully functioning EGR valve is a legal requirement of the new MOT system.  But for offroad use I completely agree with you.
Next  maintenance session I am going to take the inlet manifold off and clean it all out. I had an issue with the EGR vavale sticking so cleaned it out a while back. far amount of shit in there.
Did you make your own blank? I assume it's between the cooler and the EGR pipe. Not at the top end towards the turbo.
No . Bought a ready made stainless one . D22 Navara .
Well back to the drawing board!
Had the new radiator in a week and a bit. Did about 500 miles,  200 towing. Happened again.
I had driven 150 miles with no bother, stopped in a layby to check directions before setting off again (engine not turned off). Temp just fine. Pulled away and within 15 seconds the temperature jumped to the red line and I could see steam from the bonnet. Coolant was exiting the expansion tank rapidly. Really foamy and coming out like I'd cracked open a beer keg. Let it cool and refilled the radiator - it took nearly 5 litres!
So we'd had new water pump, radiator and thermostat. System flushed. Compression and sniff tests for the head. I am thinking EGR system has got to be the next port of call. Maybe the valve is sticking and in certain scenarios there is enough pressure that a porous EGR cooler is letting a sudden gust of exhaust gases into the cooling system. I can't think what else would pressure a cooling system so much it would be ejecting so much coolant all of a sudden.
So I can either blank off EGR and then bypass the EGR cooler with a bit of pipe or replace EGR cooler.
Its God . He hates you .
1 minute ago, Steve Bullman said:
Stubby, just in case you didn’t realise, this thread is about an l200
Has to be him . After all that has been tried I recon its Big G Spooky having a laugh . ?
