Stihl FS410c Clutch issue?
smokingdragon
1 minute ago, smokingdragon said:
Just found a parts diagram, so I'll have to take a look.
Several decades past being a teenager and don't use iPhones only androids ?
Be aware if the clutch is binding on the drum it won't pull apart when you take the four screws out. Try locking the cylinder and then carefully joggling the blade back and fore to free it off prior to dismantling.
55 minutes ago, spudulike said:
You can use some recoil rope but go carefully as some get it stuck in the ports so the piston needs to be close to the top of its stroke! It isn't a difficult job if you know your way around small engines and have a bit of mechanical knowledge.
I was wary of suggesting rope in this case because of the need to to and fro the piston, increasing the risk of a bit of rope working its way into a port. I normally use rope and have never owned a piston stop.
