Nifty lift 12 pipework.
Baldbloke
Bought myself towable lift recently for cleaning out gutters and for some pointing/reharling of walls. It just has the manual extensions for the jacking arms but came with a large charger and nearly new correct batteries. Looking at the ID plate it is from 1996. It doesn't have a loler cert as it was being used privately. My one concern is the pipework and I'd like to have an idea when pipework should be replaced although I do understand there are failsafe valves fitted which should stop the cage collapsing in the event of a burst pipe. I'm not seeing obvious cracks but some of the outer sheathing is missing. Most of the pipework runs within the hollow metal beams, and is just exposed at the ends and where the spool valves are located. What are the indications that pipework is past its' best? Is it usually replaced after a number of years or is it just down to a visual inspection?
Ten years is the maximum for hydraulic pipe but some manufactures of kit recommend changing at five years. Most mewp inspectors will condemn any chaffed or nicked pipes , pipe is lot cheaper than cleaning up the mess of a burst.
Bob
