2 stroke
mountainboy
Are you putting the oil in the fuel or up your bugle ? How did you associate the oil with the nasal beacon problem ? More likely to be a dietary or health problem than environment, eat more fruit and greens. :D
Are you putting the oil in the fuel or up your bugle ? How did you associate the oil with the nasal beacon problem ? More likely to be a dietary or health problem than environment, eat more fruit and greens. [emoji3]
Only get it when using it.
Diet is pretty spot on mostly veggie low fat low diary
Still it’s not going to be as bad as the blisters from the hog weed I just cut through agggggggg
