branch angles?
cerneARB
I have been revising for next weeks inspection course and as usual i think off more questions than whats normal..if there is a normal.:biggrin:
What do you folks think is the opitman angle for a branch before it succombs to fracture?
I know it makes a differnce due to its length,diameter,end loading,included bark, cracks and site charactristics. Are we looking at 90 degrees to the trunk (horizontal) as a bad example off opimization?
Is there a good angle for a branch which is best for it?
Depends on the species, health and situation of the tree.....there's no good or bad angles for tree branches.
Your right about that, a horizontal branch has the largest load due to the centre of gravity being at the furthest point out from the stem, but then why does nearly every species of conifer have horizontal branches?
There must be more to be gained by doing so than there is to be lost. ie. photosynthesis versus fracture potential.
The organism has many factors to 'deal with' - it reaches the best compromise.
