Hi not sharpened yet just Haven’t had an opportunity my girlfriend is doing her best to make sure I don’t over do it but back in the workshop tomorrow so will have a go I am sure I will be ok I am used to sharpening my framing chisels and small carpentry ones can’t be that different can it ? Hopefully I will get time to start a small bowl I will keep you all informed on my progress
Cheers Mark
If you're used to doing gouges then no, shouldn't be a problem.  You don't need to get them nearly as sharp as carving/framing chisels - no point in honing, 80 grit plenty fine enough imo for most things.  Find a youtube vid with similar equipment to what you have to hand.  Take note whether each tool is carbon or HSS.
Hi made my first candle stick holder will take some pics later but disaster has struck the grub screw that holds the tool rest in place has broken and I am now having trouble finding something to fit I tried a bolt but it just kep coming undone but I may have the opportunity to have a posh lathe with a movable face plate for big bowls , but going to have another go at finding something to replace the broken grub screw .
Cheers Mark
