Geotech / Chinesium generic chipper help.
bazoo132
I have just bought and built up one of the these  and started using yesterday on a trailer of brash I had approx 2-4" diameter and it ate through it quickly about 10 mins for the full trailer and fitted into one of those tonne bags so am very impressed on how it handled the branches pulling them out of my hands.
The assembly instructions were non existent and I had to follow the photos from the website to build it. The instruction manual is rubbish and as much use as a chocolate fire guard. They have included the Briggs manual.
A couple of quick questions for these type of machines. How do you go about and adjusting the anvil and what are the correct settings? How often do you lube the bearings on the drums and by how much? and how do you tension the belts as there is no obvious bolts to tighten / slacken the bolts?
In general it's seems to be quite well built for a Chinese copy.
Cheers
Baz
Edited by bazoo132
Cheers
Baz
How do you go about and adjusting the anvil and what are the correct settings? As close as you dare, you'll have to make something if there is no obvious method of adjustment. Maybe shim the knives off the drum or make slotted holes for the anvil bolts so you can slide it.
 How often do you lube the bearings on the drums and by how much? Every few hours. I do them every day on every machine regardless of hours except the stump grinder which gets done multiple times a day.
and how do you tension the belts as there is no obvious bolts to tighten / slacken the bolts? Does the engine move, if so then that's probably the belt adjustment. If not them you'll have to attach a tensioner somewhere.
Thanks Jonny69,
I have had a look at where the drum meets the anvil but it looks like a big gap. It appears like there are approx 4 bolts on the anvil but it doesn't look like they are on slotted holes.
I'll take some pics tonight. I'm quite mechanically minded but just don't know what i'm looking for being my first chipper.
Baz
5 hours ago, bazoo132 said:
Thanks Jonny69,
Baz
I ve just realised I put shim the knife off the drum.
What I meant was shim the anvil off the housing.
Hi Khriss,
Not road towable but can be towed by an ATV or similar (I think towing it with the landy would be overkill :lol:). I'll just put it onto a trailer as I'll be chipping into a trailer. They seem to have the balance point quite well over the wheels as its not too difficult to shift about. I've never used a CS100 but looking through the vids online it seems very comparable. I've got a couple of jobs on over the weekend so I'll grab a couple of vids and get them posted up.
My first chipper but it will save having to keep hiring in one. Anything oversize i'll be burning anyway so 4" suits the type of work i do.
Might try to get a smaller trailer for the jobs where the chip is being left onsite, something like the greenmech trailer.
Edited by bazoo132
