Is there anyway to improve the output of this blower.. Yes the obvious thing, by the bad b***rd magnum instead .
Could I just get a retune and make sure my carbs are correctly set. I can guess that increasing it to much would mean something would fail.
Would it be worth a rebore?
it depends if the unit used to work better and now it is a bit crap or if it was never much good and you need it to work harder? If it was never much good then you are a bit stuck with it.
  • 3 weeks later...
